Re: Raw water AC run with seacock closed.
I wouldn't (and didn't) either..... I WOULD call replacing a working system panicking....
If this is that critical then since you obviously aren't qualified to work on the system, hire a professional to look at it... I highly doubt that there is anything wrong with it tho.
Ok now your just trying to make me mad
The last 'professionals' that worked on this system rang up a 22,000 dollar bill and all they did was replace 2 air handlers, run cleaner through the system, and recharge it (possibly with the wrong refrigerant)
The other rung of professionals did similar work and decided instead of removing one of the handlers to clean the exchanger they cut a giant hole in the sheetmetal of the machine so they wouldnt have to pull it out.
So thanks but no thanks i will take a look at this system myself before anyone else does.
Not to mention i have a frigi-mar dealer coming next week to check out the system, but i will be very vigilant about what the say and do.
But i guess i dont need to know anything about the system i will just let the pros handle it.
BTW,
Seems like you may not be qualified to answer my questions.
jk
