Ranger boat trailer
RobMims
Im changing a flat but cant get the wheel off even with a sledge...I dont have to take the hub off do I?
Silvertip
Re: Ranger boat trailer
No -- you don't have to remove the hub. The wheel has rusted to the hub around the center hole and a few raps with a hammer or maul should loosen it. If that doesn't work you may need to pull the hub and wheel and work with it that way. Lay the wheel flat, put a short piece of 2x4 across the hub and give it a smack or two. If the back of the hub rests on the floor you will need to put the wheel on a couple of 2x4s to raise it up a bit.
bowman316
worst case you may need a tourch to burn it off.
may need a new wheel.
capt sam
Master Chief Petty Officer
get a can of PB Blaster and spray the wheel flange as much as you can and let it sit a little, then rap it with a mallet. When you do get it apart put grease on the flange face before you put the wheel back on.
86RajunCajun
As suggested soak it with PB blaster and let it sit. After it has sat for a while, heat the center of the rim as much as safely possible and heat the hub as LITTLE as possible. The heat on the rim will cause it to expand and then you can whack at it with a hammer carefully to break it loose.
Keep at it, youll get it off.
GL
RC
bowman316
i had stripped lug nuts on my old truck, and i had to have someone blast off the bolts with a torch. it ruined the rim too, so had to get another wheel
NYBo
Another method to try after you soak it with PB Blaster is to loosen the lug nuts several turns with the wheel on the ground and rock the trailer from side to side.
