Re: Ranch "entry gate"
Rick Fremont is in Alameda County so I can almost guarantee you that to do this right you will need a permit because you are creating a structure over 6-ft tall. Basically, anything you can walk into, on, or under requires a building permit. Arbors, those arched things plants grow on over a walkway need a permit.<br /><br />Getting a permit involves submitting plans to the building dept. They want to see a plan of how this thing will be constructed; they are looking to see where two pieces of wood come together they are joined by metal braces/strapping, etc. They also want to see how big the posts are (dia, length), and how the posts are set in the ground, how deep, how much concrete around them, etc. For a given size post there is a limit as to how high it can stand and what kind and shape of concrete footing is required. What they are after is to make sure this thing doesn't blow down in a high wind and kill someone. I'm guessing there is probably a requirement for setback from the property, too. Might be important if you are putting this thing near a public road.<br /><br />And you will likely need to submit a drawing that details an overview of size/shape and what is on the property, buildings and trees, etc. In Alameda Co, any tree with a trunk over 8-in dia is protected, $10k fine (per tree) for removing them without the countys blessing, unless it is a Monterey pine. Those trees can be removed (reference the fire in the Oakland hills several years ago).<br /><br />If you are in the Fremont hills youll probably be given a go. If you are in the flat lands (track housing) I doubt your project will be blessed. To do this right you should start at Fremonts building permit dept. They should have a handout they can give you with all of the criteria on it. You can also ask if its ok to have such a structure where your dad lives. On the other hand, you can blow off the whole permit thing and just go for it. Not likely to be an issue unless someone complains.
