Re: rakir 13 1/2 x 22
You must know your max RPM's before you are going to be able to determine anything you need to know about choosing a prop. You need to find out your manufacturers max RPM rating for your motor. Then, you need to know the RPM that you are turning your current prop at WOT. Then, and only then, will you be able to determine what you need to do about your prop situation. From experience, a jack plate works wonders and will allow you to fine tune your adjustments much more than with just standard power trim. You can call customer service for I-boats and they will formulate all of your data and determine which prop will be best for your particular boat and for the performance you are seeking.
