raker pitch size
strocker383ca
i'm running a 21 pitch raker on a 21 feet tunner hydrostream with a 200 johson ... what size pitch should i go down to do ski ,tube ,knee board ect ... should i go 19 ,18 thnx ..i wanna buy another raker prop it really work awsome for top speed and hook good .. any idea about model ,brand ??
Dhadley
Re: raker pitch size
Rakers come in even numbers so you either have a 20 or 22. If it's a polished OMC 21 it's probably an Viper. If it's indeed a Raker someone has re-pitched to 21 then it'll act like a 21 SST.
strocker383ca
i'm running a 21 pitch raker right now.. buy it brand new at dealer ... running 84 mph with it ...now i try to know what will be the right pitch for fun on lake ,ski,tube,wake board ......................
Dhadley
To make an accurate suggestion as to another prop we need to know what prop you're running now. A 21 on a 200 on a 'Stream seems a bit low on pitch anyway. To run 84 with 5% slip the motor will be running at just over 8100 rpm. While that's possible with a looper it's not likely with a crossflow. A 24 or 26 Raker seems more likely. My Vegas YT ran 88 with a stock 200 with a 27 Mazco turning in the low 70000 range.
Post the part number on the prop, that'll help a lot.
strocker383ca
ok ill try to find the parts number motor run at 8500-8600 ..the prop is running haft way out of water with the 21 raker pitch ...not sure about the % of slip ..
strocker383ca
my boat is not here but the prop was mark on the box raker but its not mark on the prop .. the prop got 3 hole in it ..i think it give air for slipage or something that way ...
strocker383ca
i was way out telling it was a 21 .damm winter i lost some info during winter :)... its a 24 pitch parts number 394755..getting older damm brain can't follow the body lollllll... miss match the rpm with my sled ..i think it run 5800..
LubeDude
i'm running a 21 pitch raker right now.. buy it brand new at dealer ... running 84 mph with it ....
Are you sure that you do not mean, Kilometers Per Hour???
If you in fact you ment MPH, Then I must call foul!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ain't gonna happen, didn't ever happen, Never will happen, not in this lifetime!!!!!
strocker383ca
bring your *** here and bring your gps ..u will be scared at 82 -84 mph lolll...tunnel hull aways goes fast
