Rake vs pitch
Barnacle_Bill
I recently had to buy a new prop to replace my damaged one. I needed to get RPMs down as they were too high. He didn't have a 23 pitch but loaned me one the same size as my old merc prop but with a lot more rake. I was amazed as it lowered my RPMs by about 300 revs and ran a lot better at WOT. I lost some on my hole shot and since I could stand a little lower RPMs, he put a cup in it. I now have a great running prop. This caused me to wonder when it would be better to recommend more rake rather than more pitch to get RPMs down a few hundred RPMs. Any insight? BTW its amazing how they put a cup in the prop. I expected to see a fancy hydraulic machine instead of a hammer and a hunk of steel.
JCF350
Re: Rake vs pitch
Rather than typing a lot I'll be lazy.:)
boatinglife.com/article_content.jsp?ID=37439
Used to cup props on the motor with 2 ball peen hammers (You swing both so they make contact at the same time). It's all in the technique.
Re: Rake vs pitch
Ayuh,......
I'd sooner think that your Lowered rpms is from the added Cupping,.....
And,....
Not the amount of Rake........
Barnacle_Bill
Re: Rake vs pitch
Ayuh,......
And,....
He told me the rake would bring it down and it did. I took it back for fine tuning and thats when he added the cup.
HighTrim
Re: Rake vs pitch
I was always told the cupped propeller of the same pitch and diameter will typically reduce your RPM by approximately 200.
Esox
Re: Rake vs pitch
bogerprops.com/PitchandRake.html
