Re: Radioshack Rectifier
I Seen Someone In A Post Mentioned A Replacement Rectifier For For The 78 1150 And Was Wondering What Exact One It Is I Need To Buy There? Thanks
Actually, Rad Shack doesn't stock anything that is suitable. You should have 25 amp average current spec, and at least 200 V PRV. This one from Mouser works, as will a gazillion others, often available at the local surplus shop. It is 600 volt. A gbpc2504 would be 400 Volts, also quite adequate. I stock these, and use them both in boats and in other high voltage applications, like 220 volt DC motor controllers. They're about 3 bucks apiece.
Go to
www.mouser.com. Search for gbpc2504 or 2506. Or search for rectifier, drill down through bridge, voltage, current, etc to get a list of about 100 that will work.
hope it helps
John
