Radio Not Working
ts2213
I have replaced Radio that wasn't working. I assumed it was radio. Upon replacing, I noticed that I do not have any voltage coming from Red Power Source. I do have power coming from Yellow Lead. I installed radio utilizing only the yellow power source for now. I have checked fuses on red power lead, all seem to be fine. Any ideas? And it is bad to rely solely on the yellow power lead?
Are you referring to the wires on your new radio harness, or the ones in the boat? I would check to see which fuse is bad in the terminal strip.
Silvertip
Yellow only powers the station memory and clock fun room. Red is needed to power the radio.
ts2213
No...the red wire coming from boat is not supplying power. I have checked fuses, I believe there were 2...both were good. So, temporarily, I doubled up the Red & Yellow wires coming from radio harness to yellow wire coming from boat. The radio works, but obviously...this is not ideal. Can I just run a new lead from battery and provide in line fuse and connect instead of searching for issue?
