Race way from Bridge to Electric panel
moylan
Hi can anyone tell me where the wireway is on my 1988 carver mariner I located it on the bridge but can't find where it ends in the main cabin I need to pull somewire for trim table controls and rudder angles thanks bye!
Fireman431
Re: Race way from Bridge to Electric panel
Follow the throttle/shifter cables. In general, you should have a recessed fiberglass storage shelf/pocket in the flybridge. This is there to cover the giant hole they had to have to run wires in the chase. It will drop straight down, generally right at the engine room bulkhead so everything can be secured to a solid wall. In my boat, access was found by removing the TV from the cubby hole and taking out the black cloth lining in the back of the cubby. The chase was fully accessible. If you have storage cabinets, look in the back of the cabinet for a cutout in the back wall, held back in place with screws. Look behind the salon sofa also. There are chase access ports all over the boat, by they are designed to be inconspicious. Many are found in the back wall of cabinets.
