Marada92
- Jan 14, 2011
- 223
Hello all.. I am tearing my Marada bowrider to redo the stringers. While trying to remove the gunnel panels I got a look at the wiring for the shift controls. I've got the quicksilver 3000, the classic I believe. It has the lanyard kill switch trim and trailer switch. Has a total of 9 wires going into it. I have a purple and purple with white stripe going to the lanyard kill. Yellow and red for the neutral safety then then red green and purple from the control to to a plug. Also there's a splice off the red going back into the control along with a blue. If that got confusing I apologize. My question is are the seperate red and blue going to the trailer switch? I'm thinking someone pieced the wiring together at some point. Would just figure instead of having two power wires coming in they would run one harness into the controls. I need to get all these labeled so bc I'm considering a new control when I reassemble everything. Thanks for any help.
The black wire is the red purple and green coming out to a plug just outside the pic.
