Frank Acampora
- Jan 19, 2007
- 12,004
I'm trying to remove a Mercury Quicksilver 3000 classic control with trim switch in the handle and kill switch attached to the front. Push center button to lock out shifting.
The problem is that I can not remove the handle. There is a slot in the bottom, but I can not find the set screw.
SO: What is the correct way to remove the control handle?
Actually, I would like to re-use this control with an earlier Force engine but cables are incompatible. SO second question is are there control cables made with the Merc control box ends but early Force engine ends?
Thanks in advance.
Thanks in advance.
