quick vacuum question
j4ivi35
Is it normal on a merc 140 to have no vacuum at WOT? If not what should i do to fix it? Thanks!
wire2
Re: quick vacuum question
Think about it;
Wide open throttle, all that outside air allowed to flow into the manifold with almost no restriction....
Robj
You are talking about manifold vacuum, which drops as rpm increases, whereas ported vacuum or the vacuum at the carb venturi increases.
Have a great day,
Rob.
