pine island fred
- Dec 20, 2002
- 1,144
Just got a call from my friend broke down at marker 34 on icw. Engine shut down temp was 140 on shut down and climbed to 180 static. Said engine was hot. Removed thermostat cover, cranked on starter and got no water flow. Sea water pump replaced 1 yr. ago and has all of about 2 hrs operating time since then.<br /> Has a cabin/beer so they are good for the night as it is getting to dark for a tow. Question, what am i looking at tomarrow? Figure the sea water pump feeds the circulation pump. Would think the circulation pump has got to provide manifold cooling water all the time. Which way does the rest of the water go? Says the thermostat housing has 4 hoses atached to it. What goes where? Can someone give me a block flow discription ? It is a 290 DP with a salt water cooled small block CHEVY. Thank you very much. FRED. PS. bondo, never did put the vegatable oil in the tilt/trim! regards
