questions on carb problem... johnson seahorse
showme219
If the "adding" of fuel by pumping the bulb @ WOT will help determine if your motor is starving for fuel (assuming it revs when the extra boost is applied)....<br />What does it mean when the added fuel stalls the motor out ?? This happens to me when I use WD-40 or Starting fluid at idle AND WOT. <br />My UNEDUCATED guess would be that the boost fuel is using-up what little air I am getting into the combustion chamber. Is that a sign that I am getting TOO MUCH fuel ??<br />The symptoms are 1) rev's to only 40-50% of what (I think) is normal. 2) will not pull my 15' boat over 3-5 MPH. 3)Idles great, revs to "mid-range" fairly well 4) no power from 1/2 to full throttle. 5) occasionly with surge for a second, seeming to rev-up, but that is always short-lived !! lol<br /><br />also, the motor is NOW a '62 Johnson 40HP. Curiously, it was a 65 horse when I bought it ?!! Shame on me for not investigating a little more !!<br /><br />lastly, were IS the High-end fuel adjustment on this thing??
JB
Re: questions on carb problem... johnson seahorse
Howdy, Bilge Pump.<br /><br />Sounds like you have adequate mixture if adding fuel stalls the engine.<br /><br />WD-40 is no longer a good booster fluid. They used to use propane as a propellant, which made it a fine starter fluid for 2 strokes, but they have switched to CO-2, which is a killer rather than a help.<br /><br />Use a spray bottle and fuel mix.<br /><br />I assume you have checked for strong, hot spark in both cyl. If not, do so. No spark is your most likely suspect.<br /><br />If you have checked for spark, try running it on one cylinder with the other plug wire off. That will tell you if you are on one.<br /><br />Good luck. :)
showme219
both plugs fire... lower one doesn't seem to be quite as blue and tends to be "wetter" on inspection than the top one.<br />so, my mixture appears o.k. then ? .......<br /><br />I just called the local marina, he said, from my brief description, that it sounds like a coil problem...... any comments?<br /><br />Thanks so much for the quick response !<br /><br />Steve
rolmops
Hello.<br />Before you change the coils,you might want to check your points and the cables that go from your coil to the spark plugs.<br />I find it cheaper to eliminate the simple things first.
rolmops
Hello again.<br />On second thought,pumping your bulb is the key to your problem.<br />This will only add fuel in case the fuel can leak past the float in your carburator and go into the system.<br />Chances are that it leaks all the time and thereby gives you a much too rich fuel mix.By pumping your bulb you make it worse and it shuts your engine down.<br />Before you act on this suggestion we might want to have it confirmed by smarter people than me.<br />The high end needle valve is on the the lower end of your carburator.It goes straight into the bowl.Have a care though,for some of these engines have a static high end ( e.g. unadjustable)
JB
What you say would make a lot of sense if it had multiple carbs, Rolmops, but it has only one, feeding two cylinders. If I am wrong here, please straighten me out, BP.<br /><br />A broken or chipped reed could cause a loss of power in one cylinder, even if it had strong spark. That's why I suggested trying to run it on one. If only one cylinder is losing power, it is a lot easier to isolate the cause.<br /><br />I agree with Rolmops on switching plug wires, plugs, and even coils to see if the trouble follows a part. The 1962 40 has a dual magneto. You need to check the points (set at .020). I would just replace the condensors, they are cheap. <br /><br />Good luck. :)
BKool68
I also think you should switch the plugs wires and coils one at a time and see if the wet plug moves. If it stays you may have a head gasket leaking water into that cylinder.
showme219
You guys are great ! Now all I need is a "picture" of the parts you guys are mentioning ! ha ha !<br />My local "boat place" can get me a manual within a week or so, parts may take a little longer !<br />When I say I need a picture of the parts... spark plugs, wires, carb, and such, I recognize...! BUT condensor ? Coil ? Stator ? <br />I've pulled the top off of my '69 Johnson 25 HP and replaced the points, can I expect this to be the same ? <br />I pulled and cleaned the carb last night.....a little note for future references.. the POINTED end of the "float needle valve" goes DOWN !!!! LOL
BKool68
Actually if the carb is upright the needle points up. But we normally have the carb upside down to rebuild.
