Please forgive me here, i am a true novice on this... i have a 15 hp sears gamefisher motor that i picked up from a neighbor. actually runs great. first... i believe it is a chrysler engine, but how would i be sure? also, i'm not sure what year it is... i've looked, but cannot find a year on it or serial number... how do i determine this? I've found online that it would have to be between '80 and '98. I'm assuming its a 1980 model, based on what i've found online. again, i'm new to this. this is actually my first motor and boat.
i need a replacement propeller, but i'm having a very tough time finding one. I can email a pic of the propeller (and the motor, if necessary) to anyone that can help. The propeller on the motor now is an after-market, i believe, and i cannot find anything like it. I've found online that the part number for the OEM propeller should be "fp408"... i think. "8 1/4" D X 8 1/4 P" is stamped into one of the blades, which i am assuming is the diameter and pitch. Anyone know where i can find a replacement?
Another question... it's a 2-blade prop, and i'm wondering if a 3-blade would help with thrust? boat runs smooth, but seems kind of weak (apart from the fact that it's only a 15hp!) and i'm wondering if a 3-blade propeller would help... I am seeing that there is a 3-blade that should fit? part number "48-fp70". (see http://www.properpitch.com/pdf/MWfcm.pdf). I've searched for either part number and no one seems to have in stock. also searched the "michigan wheel" part numbers and i'm not seeing where i can order. ?
sorry for the long post... thank you for any help you can give!!
