questions about shift linkage...
ggarrett
ok, i am new to boat motors, and cant afford to take it to mechanic......So, thought i do most of everything myself...
I put new water pump in, think that went well, but had hard time with connecting the linkage back up......went to try to start it, and the prop spins in neutral.........Im pretty sure that isnt supposed to happen.........How do I fix this?? Hope its an easy fix.....oh, its a 30 horse suzuki, 1989 model
deejaycee_2000
Re: questions about shift linkage...
If you put it in forward or reverse you will see the linkage move, thats the only way you can catch it and link it back up properly ...
ggarrett
i checked it last night when i got home.........prop in neutral when shifter in reverse position..............it was raining last night so i didnt get to mess with it...........
So, when gear shifter in neutral, the prop in in gear when it should not be.........
So,what the proper way to fix it.........drop lower end again and restab it??
99yam40
yes , drop lower again and make sure shifter and lower unit are in the same gear when putting back together
ggarrett
How do I know if the lower unit is in Neutral?????
99yam40
turn prop and see if drive shaft turns or not
Or the other way around
ggarrett
ok, i took off thw lower unit, it props spins one way, so so i shift the into gear first now. how do you know if its in forwRd or reverse
ggarrett
what way does prop spin if in forward. the bar is spinnimg right to left. prop turning right, looking st it front to back
deejaycee_2000
if it is in forward it will spin freely anti-clockwise, if it is in reverse it will spin freely clockwise .... (well not freely but it will make clicking sounds) .....
ggarrett
ok, so, when i decide what way it is spinning, am i facing it from behind the motor, like sitting on a chair spinnng the prop, or looking at it from on the boat
Pas Bon
Look, you are making this too complicated, the prop is shaped in such a way that it slices through the water. Look at it which way looks like it should turn to go forward.
Get the prop in neutral, put the shift lever in neutral, put it back together
