I have a friend with a 2002 Crest 22' pontoon boat and a Suzuki DF60 4 stroke motor. The motor should also be around the 2002 model year, they were bought new at the same time as a package.
Yesterday, we took it out for the first time this year, and everything was fine until we hit full throttle. Usually full throttle was between 4200 and 4400 rpm. This time if we tried going above 3900/4000 rpm it seemed as the prop was momentarily slipping. The engine sound changed and the tach jumped up for a brief moment and then back down. At first I thought it was missing as the boat lightly jerked everytime it happened but then as I watched the tach I noticed it jumping up everytime it occurred. Below 3900 rpm we didn't have any problems.
Does the above sound like a slipping prop or some other problem? I am trying to help him out as much as I can as he's older and has had major back surgery and is still recovering.
Aside from that, I would like to do some maintenance on the motor for him, like change the oil, replace the water pump/impeller, fuel filter... can these things be done with the boat in the water? We have no trailor for it and it is docked in about 2-3 feet of water.
We'd appreciate any ideas/thoughts regarding these questions. Thanks.
