Re: Questions about 1973 Starcraft 16' SS
Thanks for the info, did not know it had to fit between the stringers, I was under the impression that there were grooves in the bottom of the tank to allow for that, but I guess that would be impossible since all boats are different. I also checked the moeller website and read more about the below deck tanks...hmmm, I think there are too many things that could be hazardous to keep a tank installed in this boat. I live near the Chain O Lakes, IL and we can have some pretty harsh winters. I think maybe I will stick to the above deck tanks so they can be removed when the boat is stored. I have two old metal tanks that should be replaced, which is why I was considering the change.
Some background info on this boat...I just changed to the '73 SS because my 15' Capri needs a new transom. I put about $1600 into the 85hp OB and last Friday when we took the boat out, the fiberglass broke apart and all the rotted wood in the transom was floating in the hull...good thing we did not sink or lose the motor off the back of the boat. The SS has a new transom and is a solid aluminum hull, no leaks...can't wait to get it out on the water this weekend.
