Question
John115
I've got a 1983 Ebbtide Bass Boat, on the dash someone marked a switch with tape that says Belg. I fliped the switch on and it started pumping water out of the rear of the boat. I looked all through the boat and could not find where the water was coming from. Does anyone know what that is and where the water is coming from. Thanks
Dave1027
Re: Question
Some good ole boy misspelled it. It should be labeled "Bilge". The bilge is the bottom of the boat and the switch activates a pump that pumps out any water down there. Maybe you have a leak? You better get that checked.
