I am rebuilding a 2001 200HP Merc with no EFI.<br />Got a bad cylinder after I lost the oil feed to the engine.<br /><br />Damages assesed upon ripping it apart. Bad piston, minor scoring to the one cylinder, oil drive gear needs replacing, and a few bits of broken down material here and there (from the piston or oil gear).<br /><br />I noticed that there are about 4 bands or c-rings that buffer the crank shaft and keep stress from the bearings.<br />One of those was broken. <br />I was wondering if this is common or a result of the engine being run with no oil for a short time.<br />All compression was good except for my one bad cylinder.<br />should I be worried about crankshaft damage (warping ect?)<br />Anyone see one of these buggers break before.<br /><br />thanks,greg
