askmelater
- Sep 14, 2010
- 23
I'm working on my 115HP Ficht motors and was wondering if there is any problem with manually turning the Motor over using the Prop (if possible).
It's difficult to turn the top flywheel.
Also,
I'm not sure if one of my motors is having a Bearing issue or a Gear Issue.
I was going to remove the Leg and was wondering if I can start the motor up using a hose to inject water into the water port to eliminate the Lower Gear as a problem.
I have an engine knocking sound and I'm not sure if it's the top or the bottom (sound traveling up the leg).
Thank you.
Also,
Thank you.
