Re: Question regarding plug wires
Usually not, late model plug wires are carbon core based and can cause problems with older ignition systems. Stop by your local marine dealership and they should have plug wire on a spool, buy the length(s) you'll need by the foot. The wire you're looking for is 'wire core', several strands of solid wire within the insulation. This type of plug wire was common on older 60's automobiles.
