Having troubles starting a 91' 60HP Johnson... someone who is had a similar problem suggested to me to check the kill switch to make sure it was all the way out. If the kill switch was malfuncitoning and was still partly engaged...what would happen when you tried to start the motor? <br /><br />Would it crank but not start?<br /><br />Would it crank at all?<br /><br />My motor cranks, but wont start...I was curious if this was a possible answer. Thanks
