Question re: engine swap
suparye
I currently have a 2000 Volvo Penta 7.4Gi PEFS (454) attatched to a Duoprop.
I have a few questions regarding replacing the current engine with a 5.7l
Will a 5.7 bolt up to my trans?
Will my exhaust (not including the manifolds) be the same?
Are the motor mounts in the same place?
Will my current remote oil filter work on a 5.7?
Will my current alternator work?
Will my current starter work?
Will my current power steering and cooler work?
Will my current fuel system work?
I know this is a loaded tread just looking for any answers I can find.
For what its worth there is nothing currently wrong with my engine, she runs like a kitty. I'm just future minded and parts for the 7.4 are much harder to come by; ie: cooling kits, manifolds, ect.
Thanks in advance guys.
Re: Question re: engine swap
Ayuh,... Can't answer yer questions, for Sure...
But,...
Goin' from a BBC to a SBC, the boat will be a Dog...
And, at this point in time, BBCs are Not at all scarce...
Don S
Yes, but the gear ratio in the outdrive (not called a transmission) will have to be changed for the smaller engine. $$$$$$$$
Some of it
No
Should
While the units may work, all the brackets are completely different on the 5.7
No, and neither will the wiring harness and the computer, and other sensors. BIG $$$$$$$$
Stick with what you have, the parts are no harder to get for a 7.4 Volvo than a 5.7
suparye
Well that settles that. Thanks guys.
Don, you'd be surprised how hard it is to find quality aftermarket parts for the 7.4.
It sucks that you can get nice Osco manifolds and risers for a 5.7 for $499 but for a 7.4 $1300, and I have to buy VP.
Same with FW cooling kits. 5.7's have nice and cheap on motor kits whereas 7.4's have ugly off motor 'block only' kits.
