quackaddict1
- May 30, 2008
- 138
Hey guys, Well, my motor is finally working the way it should (95' 28hp), It starts and runs smoothly and winds up fine in the tank. Before I take it out I need to time it, the starter says 30 degrees and there is a white mark on the flywheel at 30, I would assume you use a timing gun to align the white mark with the notches on the plastic piece below the flywheel? You adjust using the big screw on the throttle linkage?
Also, I am currently looking for a service manual so I can stop asking a ton of easily answered questions here. Are the seloc versions worth having? I can find these with no trouble but The actual Johnson versions are harder to come by, anyone have a link?
Thanks again guys..
Thanks again guys..
