I need some "Straight Talk" on an opportunity to purchase a boat that needs a new Gear Housing and Bushing (omc part #982226) on the upper gearcase. As best I can tell the boat has a 1984 OMC 3.8L sterndrive. The motor has less than 700 hours on it. The problem is that the Gear Housing is cracked and needs to be replaced (it sounds as though all parts are there). The damage was done when someone was trying to raise the outdrive by towing along the boat ramp. Apparently, there was an electrical problem that prevented the owner from raising it the usual way. Anyway, in the process the Gear Housing was cracked.
I am not a professional, but am mechanically inclined, can follow instructions in a manual and have done some work on small outboards in the past. My questions are how difficult is this job and what would be a fair range to pay for necessary parts?
The outdrive was damaged about a year ago -- is there anything else I should be concerned about? I'm not sure if the fuel tank has had fuel in it all this time etc.
The reason I'm even considering is because of cost. The boat an early 80's Sea Sprite appears to be in good condition from the photos (haven't seen it in person yet) and can be had with trailer for less that $1,200.
Appreciate the thoughts of those more experienced than me.
Dan
Dan
