Re: Question on installing a Generator (Costs?)
OK thanks guys, so what you're saying is if it does not come with a generator, just don't buy it?
You can find them in that length with onboard air pretty easily. You could go the route of strapping a generator to the swim platform if you wanted, however that opens up a ton of other issues. Many safety issues and some logistics (probably don't want that generator back there when you are out on the water).
To properly put in an onboard generator you would have to figure out how to get it in there in a 26' boat (pull the motor probably). Cut holes in the hull for water inlet and exhaust (not that bad). The panel / wiring costs could potentially be very high. I'd research that part quite a bit. I've seen just single transfer switch to go from shore to generator for a $100 - $400 depending on the number of shore power plugs.
My suggestion though is to find a boat that has the generator built in already so it's wired 100% correctly, you get the gauges and switches where they belong and placed random places, etc. They do make them in that length, they are just harder to find.
