Question on 1986 mercury outboard
jimmbo
If both are 3 cylinder loopers, it should swap, if the 80 is a 4 cylinder, I don't think it will
flyingscott
Is the 90 a TOP 6? If the 80 hp is a 4 they might interchange physically but the gear ratios might be different. Someone will be along who knows way more than me.
jimmbo
An 86 90 hp would be an inline 6, the 3 cylinder appeared in 87
There was no 80 hp in 86. the last 4 cylinder 80 was 1983, the 3 cylinder 80 appeared in 87
That is why Model #s are very important
An inline 6 90 hp had a 2:1 ratio, the 4 cylinder 80hp had a 2.3:1 ration. The 3 cylinder loopers also had a 2.3: ratio, but the gearcase might be like the one used on the 4 cylinder loopers, different from the ones used on the older inlines
