Ok, I've owned lots of Yams including Ox66s, F115s, etc - but my new F150s have the new gauge pack that has a lot of infomration on there, and I've got a question...
Under load the temperature gauge reads in the upper half of the range. At idle or under light load its dead center (once warmed up).
The engines do not overheat and both (I have twins) show the same readings under power.
The gauge looks like this when under load:
C|___|___|___|___|_V_|___|H
The "V" is the pointer, obviously....
I'm used to gauges being calibrated so that the "center" is the normal operating range. This looks like they're running warm - not hot, but warm.
Propping is correct (right at 6k RPM WOT with a moderate load) and they're running great.
Of course what I don't get from these gauges is an actual TEMPERATURE! Argh.
Is this expected behaivor? This is my first time with an outboard that has an actual temperature GAUGE!
