i am swapping a 2004 vortec 3liter,with hei ignition for a 1989 omc 3 liter with points ignition. i have decided to stay with the points system. if you went that way what specs did you use to time the engine. if you switched to hei could you post any info or tips you may have. i have the diagram for the diode and resistor setup for the shift interruptor. i also had to get a new coupler and am waiting for it to be delivered as i write. fbyrnes@suffolk.lib.ny.us
