Re: Question for Elvin;
The situation is the following: The sticker on the side of the engine says: Idle 900rpm out of gear, and in gear idle: 750 or 700 rpm (I don't remeber). I have found that the engine is happiest at 800/600 rpm (out of gear/in gear) per the OEM gauge. If I raise it to 700+ in gear, then when I put her in idle, it goes up to about 1000 rpm (too high). Even setting it at 900 rpm per OEM gauge when out of gear seems high because it shifts hard at that speed and the tach drops down to just a hair above 600. If the gauge is off and shows less by say 100 rpm, then the 800/600 is about right. at 800/600 rpm, when flushing with earmuffs on land, the engine idles at about 1000-1100 rpm, I imagine the increase is due to lack of any exhaust backpressure. If the tach is correct, then I do not know what it could be as it is impossible to achieve the speeds on the sticker. BTW, I used to have a Tohatsu 40D on this boat. When I repowered, I used the Tohatsu gauges for a while, then after a year replaced all gauges and harness with the ones supplied with the 90A. The swap did not resolve the situation. How arbitrary are those speeds on the sticker, are they rock solid or for reference only. The timing is set at 5 ATDC at closed throttle as per sticker/book and carbs are synced and pilot screws adjusted. <br /><br />Also, being that this engine uses a CD Unit, is it true that they need at least 600 rpm to operate and give proper spark? <br /><br />Normally it would not matter so much, but I do alot of trolling at idle, and want to make sure that the engine is properly tuned for that speed. Thanks in advance for your help!
