killer14163
- Jun 10, 2008
- 20
i found this service bulletin that is for the gasket kit that i have for my oem volovo penta Manifolds and gaskets that i am putting on my 4.3 gxi 2004
you posted this procedure which is what it says with th gaskets that i bought but i found this after and its dated after your post so has it changed? what would you do at this point ?
here is what yu said and posted
Default Re: 5.0 GI Exhaust elbow gasket 3863191 installation
Here ya go.
http://www.4shared.com/file/25218877...r_Gaskets.html
here is what i found after date of your post
http://www.google.com/url?sa=t&rct=...sg=AFQjCNGp0SXF2VzdX-ADRkd_vBvACUwJkQ&cad=rja
Change to Procedure:
Before installing a riser gasket, coat the mating surfaces of both the manifold and the riser with a copper-based, heat- resistant gasket compound.
Examples:
Permatex Copper Spray-a-Gasket? (80697) K&W Copper Coat? (401612)
Aerosol or brush-on applications are both acceptable.
do you sugest the spray on stuff or stick to dry method?
or is there a bulletin after this one?
thanks
tracy
Here ya go.
Examples:
thanks
tracy
