JJB
- Dec 28, 2006
- 274
I have a question about gell seal that I be using to seal the crankcases of my 175 Johnson . The manual tells you to use omc gell seal and to prime with loctite primer . First do I need to use the primer and IF SO which one do I use and where do you get it ? I also heard that loctite 518 is the same as gell seal , is this true ? Thanks !
