Question about FLO-TORQ II hub assembly kit difference
bigpetee
I have a 2001 Bayliner 2150 Capri - 305 Alpha I gen II - 14.5" 19p prop. I had my prop touched up/painted this winter and wanted to replace the hub kit as well.
I ordered 835257K1 which should be the correct application for my boat. It looks like this:
My old hub and most of the pictures I see online look like:
Did Mercruiser modify the hub kit for my drive? Is that the correct hub kit?
Thanks so much-
Peter
Re: Question about FLO-TORQ II hub assembly kit difference
Ayuh,.... Welcome Aboard,... It appears to be 2 pictures of the same hub kit...
Why do ya wanta change a perfectly good hub kit,..??
bigpetee
Thanks Bond-o.
I ordered a new one mainly to have the old as an on-board spare. I just wanted to make sure it was a part revision/difference and not the wrong kit.
Thanks for the quick reply.
John_S
FWIW, all black max props I have had, had the kit in pic #2. Pic #1 has a different sleave and nut locking mechanism. Maybe a new revision?
90stingray
I believe that pic 1 is a Sierra brand (just looking at the lock) and pic 2 is the Merc product. I have had both and they function just the same. BUT the locks in pic 1 are just a tad harder to locate.
