sutor623
- May 23, 2011
- 4,089
Ok guys I have a sweet '84 evinrude 75hp. Runs great. Nicest outboard I've ever had actually. Anyways motor ran great when I bought it, compression read 138-140psi across the board. Me not knowing exact history did a full fuel and water system overhaul. Even put a new fuel pump in it. So I did a link and sync and motor is running perfectly. Put 10 hours on the motor in the past few weeks and decided to pull spark plugs to check for lean conditions via spark plug diagnosis, and decided since plugs were out to redo compression test. The gauge I have has been around for about three years and I have tested many motors with it. From 0psi to 220psi in a car. Retested compression and it read 150 psi all across the board!! So what gives, why the change? Obviously I used the same gauge both times.
