question about automatic oiling system
bg175
I've got a friend with a 1980 150 johnson. It fouls plugs, excesive smoke, and runs rough. The plugs are oil fouled. Can a person regulate how much oil the pump puts out. Or just do away with it and premix the gas. Any help would be appreciated.
larky
Re: question about automatic oiling system
i am no expert but I've read that the problem could be cracked and leaking gas lines alowing more oil per unit of gas
dajohnson53
Is this an oil injection fuel pump (also known as VRO and OMS) or some other system. I don't think that 1980 engines had VRO/OMS.
DHPMARINE
We probably should start with a model number.I don't think the 150's had an oil pump before 1984.
DHP
1730V
DHP is correct. No oil pumps before '84'.
I'd be looking at carburetors. Time to rebuild them and replace every hose under the hood.
Dhadley
What spark plugs are you using?
bg175
I was wrong, it is an 86 model. I am not sure what plugs.
Thanks
bg175
I was wrong, it is a 1986 150. I'm not sure about the plugs. Please help
iwombat
Like was mentioned before, the most likely cause for over-oiling is an air leak someplace before the VRO unit. That will also cause the rough running you described earlier.
Dhadley
It's possible to get an incomplete burn with the wrong plugs too. Start with the basics. What plugs are in it?
