Re: question about anchors
xecutech, some boats have a dedicated cleat in the center of the bow, if yours does use that one, otherwise, it should have 2 cleats on either side, either of those will work. If it is easy to get to the trailer eye bolt, you could use that, but if there is an emergency, it may take too long to untie it, so a cleat topside is best. In a perfect world, you should never anchor from the stern. However it is done to prevent the boat from swinging on the anchor (a crowded anchorage). If you do anchor from the stern, I would recomend an anchor that doesn't hold as well as the primary off the bow, such as a large mushroom type.
