QL78YC VS QL82YC
KCMILLS
1996 200 hp oceanpro manual says OEM 1996 service manual says use the 82 but the champion plug charts says the 78 what gives?? the 78 should be the hoyyer plug correct what should i use
Walker
Re: QL78YC VS QL82YC
You have it backwards. Champion plugs are hottoer the higher the number. The 82 is a hotter plug than the 78.<br />If I remember right the factory specs have been changed for most of those motors that called for the QL82YC.
KCMILLS
so should I run the 78 then? that is what the champion chart says? thanks
KCMILLS
does anyone know what the cross ref for a NGK plug is for both these plugs the QL82YC and the QL78YC ? thanks I like the NGK over the Champions
angus63
Your motor likes Champions over the NGK<br />Chart calls for QL78YC gapped at 0.030"<br />I use em and recommend the same<br />NGK run a bit hotter and can be a problem
