QJet to Edelbrock 1409
435D3
I have given up on my Qjet on my 85' Mercruiser 260. I need help figuring out what to do with the fuel sight tube from the fuel pump to the carb. The 1409 only has vacuum ports and a PVC port but I do not want vacuum on the sight tube. Any Help would be most appreciated.
Scott06
Just below where the flame arrestor goes on the carb on the back left side there is a 1/4” nipple that sticks out fir the fuel pump diaphragm rupture overflow tube. Its at about 10 oclock if you look down at the top of the carb
435D3
Thank you for the reply. that is where I shall put it then
