This motor is new to me, but is a '55 model. I put carb kit in, changed impeller, and it starts good after setting low speed knob. Wouldn't go much faster than maybe half speed. I can move the rear butterfly by hand and the thing runs great. Set the high speed knob best as could (steering the boat, holding the butterfly open, and adjusting knob was interesting). I put the linkage for the butterfly and the arm that goes to the cam and roller back the same way it was before I took the carb. off. From the way it looks, it seems the linkage is too short. Would anyone with a serv. manual be able to tell me how long over all that linkage should be? Also, when I turn the throttle knob to wide open (not running,just working the throttle trying to figure it out), the cam roller runs out of cam and falls back under the timing plate. This seems like it would make the motor fall flat on its face. Is it supposed to do this? I don't have a serv. manual yet, but looks like I may need one. The motor runs great as long as I work the butterfly by hand. Would the linkage still be available? According to the parts manual I bought off of ebay the part number is 303539. The cam roller is also missing the top bushing and retainer, part numbers 303279 for bushing and 203363 for the retainer. I have found other things the previous owner did such as the knobs were backwards but the carb. was pretty clean considering the age and condition of the tank and fuel filter. I cleaned up the tank, put a tank to fuel pump gasket, replaced the filter, all the hoses. Runs and starts ok, just no WOT due to the linkage won't allow the throttle butterfly to open all the way. Could someone tell me if the linkage is available and if so, how long is it, and could the timing plate and cam be misaligned?
