Q-Jet Rebuild question.
captmello
I'm having my carb rebuilt.
Do I have to buy a marine specific carb kit or will an automotive kit work?
Thanks.
BaileysBoat
Re: Q-Jet Rebuild question.
Carb kits are ordered according to the casting number, there is no universal kit.
dan t.
when you order the kit,order a new brass float and a new choke pull off . the foam floats soak up fuel and get heavy after a few years, the choke pull off which also dampens the secondary air valve, can spring a leak after a few years. you should replace these parts for a proper rebuild
