Re: PWC TRAILER TIRES IN SAND
I have a small utility trailer I made for hauling fire wood out of the woods. I had small narrow tires and had the same problem of them sinking and causing me to get stuck many times. I found that golf cart wheels have a 4 inch bolt pattern with a rim diameter of 8 inches. You can purchase highway tires for these rims. So far I haven't had any problems. I pull this through the woods as well as the highway. However, keep in mind, if your going 60 mph, those little wheels are probably turning about 80mph or more! Any small tire diameter will have failures at higher speeds.
