Re: PWC Storage (winter)
Chiboka...to winterize, no need to drain or run out fuel, in fact full tank of fuel is better to reduce condensation. The fuel needs to be stabilized, however, with a good fuel stabilizer (about $4 worth will do 20 gallons of fuel). Don't get the cheap stuff, you'll know the good stuff because one ounce is recommended for 2 to 2.5 gallons. The cheap stuff says one ounce will stabilize 1 gallon of fuel.<br /><br />To winterize:<br />1 - Add fuel stabilizer to fuel<br />2 - Run engine on hose enough to be sure 'stabilized' fuel has entered engine.<br />3 - Switch to running engine on antifreeze solution You may need a kit or a bucket with an attachement to feed the cooling system, just like the hose attachment.<br />4 - Wait until you see solution is exiting, and run another 3 minutes or so.<br />5 - Using an engine fogger, like 'Engine Stor' or other brand, spray into carb or air intake.<br />6 - Spray for about 10 to 12 seconds, or engine may stall (it's OK).<br />7 - Remove each spark plug and squirt engine fogger into each cylinder.<br />8 - Although not specific to winterizing, there are other things that can/should be done at end of season or regularly - lube drive shaft, check impeller condition and alignment, tune up for next season so you're ready to go.<br />9 - Next season...don't forget to replace plugs, start engine with the old plugs if possible, burn off engine fogger, then replace with new plugs.<br /><br />Any one else have a different procedure??
