PWC Cooling Systems
Jack Shellac
I don't know much about how the engine is set up in these things, but need to take a look at my son's Tiger Shark. Do they have a seperate water pump for cooling like regular outboards or do they get the cooling water from the drive impeller somehow? Will appreciate any advice on engine running a little hot.
Seaboo2
Re: PWC Cooling Systems
First may I sugest to you yo consider buying a manual. They (to my knowalage) not have a water pump. Normally if they are running hot you start by checking the fuel mixture.
BiXLL
ski gets cooling water from jet pump. You will see a line (water) going into exhaust manifold. If you have any kind of obstruction in your intake/pump area, you could over heat! Take intake off, look for foriegn objects (sticks, bottle caps, sea weed, ect)
Jack Shellac
Thanks for the info, guys. Know where to start looking, now.
MrBill
Different makes may vary significantly...I'm familiar with Bombardier (Seadoo) machines, and many vary by model. Most (maybe all) of the Seadoo models have a small hole at the base of the tow hook (if equipped) at the rear of the machine which expels water. If there is no flow from this 1/8" hole, an obstruction of some sort is prohibiting proper flow and affecting cooling.
doman
What engine do you have ? is It 700cc yamaha? if so usually its just the exhaust manifold overheating ..you should be able to touch the manifold everytime you run the ski if its to hot to touch its prolly clogged
