putting waterpump and seals in lower unit
apoboy1985
I need help putting my lower unit back together because when we pulled it apart to change the waterpump and gaskets/seals everything was tore up from the sand or something getting in there and we do not know how it all goes back together. Does anyone know of any sites or anything where i can get detailed pictures of the pieces and where they go? i have a 1976 Mercury model 1150, 115Hp 6 cyl. If you have any suggestions please let me know, thank you,<br />anthony
CU2NITE
Re: putting waterpump and seals in lower unit
WWW.dougrussell.com You should also get a manual for you motor. It will always come in handy!<br />CU<br /><br />--------------------<br />RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
apoboy1985
now do you know if the manual on that site is a very detailed one? i need it to be very detailed so i can see where everything goes
apoboy1985
also this is an outboard engine, not the inboard gm, ford, etc. thanks
DHPMARINE
On the dougrussel site,click on part search,then click Merc,then HP,then serial #.Then select gearcase.Pretty detailed pics.<br /><br />DHP
