put a bravo2 lower unit in a bravo1 outdrive
vicdur93
Can you put a bravo 2 lower unit into a bravo 1 outdrive without any major work to be done . The reason I 'm asking is someone did it to mine and I want to put a bravo 1 back the right way.
Re: put a bravo2 lower unit in a bravo1 outdrive
Yep......<br />No Problem.........<br />You can bolt on a B III, if you want.......<br /><br />Except as you already Know,<br />You can't find the Right Props........
