Push Pull vs Low Friction Cables
khobombed
I just finished pulling out a 30' cable from my throttle control to a BF225 through the boat and need to order another one. The old cable sheathing has been cut and has rusted through so its beyond repair. When I'm looking for a new one to order I see both "push pull" and "low friction" type cables and being quite different in price. Also I see either "obsolete" or "call us" for the 30' lengths of low friction. So, what is the difference between the low friction and push pull cables? :confused: Your sage advice will be greatly appreciated.
pvanv
Re: Push Pull vs Low Friction Cables
"Push-Pull" applies to all OB RC cables. "Low-Friction" is a fairly "modern" term, and is basically a marketing terminology. The 30-foot (9.1-m) Morse-style cables are still available. In our shop, we typically use the Hi-Lex cables, which are relatively high performance at a moderate cost. The Tohatsu number (since we are a Tohatsu shop) for your specified cable is Part# HC49J96-30FT, $59.25, and fits any modern RC box. Unless there is a compelling reason otherwise, we would normally replace both the throttle and shift cables at the same time.
