Push choke in and get more power? 120 everude.
malone2
120 evinrude runs fine but noticed that if push choke in while running in gear it peps up more rpm.Is this normal,if not are the carbs stopped up or ??? :confused:
wilde1j
Re: Push choke in and get more power? 120 everude.
Your engine is running too lean. Find the source of the problem before you fry the powerhead. Probably carbs need cleaning, but could be fuel pump or plumbing.
