push button ignition help
tommyk021
Hi I have a Johnson 60hp 2 stroke Key start engine
While i was out the other day a wire in the ignition finaly broke off its connector from corrosion ..there is not enough lenght on the wire to reconnect it so i was thinking of putting in a key and push button start on the dashboard instead of replacing the loom cables..
In the back of the current original key start switch there are 4 wires attatched
does anyone know what all of these are for and how could i set up the new start circuit??
Thanks Tom
Daviet
Re: push button ignition help
What year is your engine, what color wires are you working with?
