Purpose of motor trigger.
rodbolt
Re: Purpose of motor trigger.
its for killing the engine, pull the trigger and its dead :)
rodbolt
hahahah could not resist, can we get a bit more information about the motor? HP year seriel numbers.<br /> the trigger in the battery CD system is somewhat different than the ADI system but both basically provide a "trigger" signal to the switchbox so the switchbox can discharge the capacitor through the SCR that just got "triggered" into the ign coil primary windings.
glizama
let me start all over. Im having problem with my 115 hp mercury mariner.s#A959255 it idles fine in neutral but when it under load it falls to its face immediatly. tried squeezing the ball but still the same.compression is good. Im sure if its the trigger or the stator. I've rebuild the carb twice but still the same. new plugs & wires, new power pack, coils I don't know what to do pls. help also would like to know the year of the motor. thanks
rodbolt
I am lazy tonight and dont feel like looking, can ya tell me if you have a distributer or 6 seperate ign coils ?
glizama
no i don't have a distributer i do have the coils
andy6374
Have you checked for spark on all cylinders at idle and when you go to get on plane? If you've got fuel and compression then a lack of, weak, or ill timed spark is your problem.
roger3645
Do the Timing and Sync posted by Clams dtd 18 May 06. I think this will take care of it. I had the same problem which a simple adjustment of the idle screws on the carbs took care of. You can also attach a timing light to each spark plug wire to see if you have good spark to each plug.
Texasmark
Answering your initial question, the trigger is what initates the energy transfer that fires your spark plugs. It's timing with respect to the piston's position in the cylinder (crankshaft relationship) determines if your engine will fire at all and accelerate under load.<br /><br />Mark
